2019 Honda Talon 1000R rear frame cracks
SLOWPOKE693
SLOWPOKE693
2,025
7,849
Somewhere in Texas
An no problems on a completely reworked and much stronger frame. You are helping prove my suspicions.
AND I beat the crap out of my Talon probably more than most here. I definitely stress those sway bar mounts! I had a feeling when I was building it that I was doing the right thing by cutting all the stock stuff off back there.
SLOWPOKE693
SLOWPOKE693
2,025
7,849
Somewhere in Texas
My buddy has a 19 R model with the same swaybar and runs it in the same position we do. He races XC but his frame is still 100% stock. I sent him the pictures you posted and told him to check his when he gets a chance. I'll report back when I hear from him...
SLOWPOKE693
SLOWPOKE693
2,025
7,849
Somewhere in Texas
Just heard back from him. My buddy said his frame is fine but another guy he races with that has a Talon had his frame break in the exact same spots on both sides. That guy also runs an Eibach sway bar. I'm starting to see a trend here...
It's also probably the one some of you remember seeing. My buddy said the pictures were posted a while ago in a FB group. He's going to send me the link if he finds it. I don’t FB so I'm of no help there.
Killer223
Killer223
265
530
mine broke same place here is the fix i came up with.
IMG 9541
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
Just got her all fixed up this past weekend thanks to one of my moto riding buddies.
We used a floor jack and ratchet strap to line things up.
IMG 20211120 111926473 HDR XL
IMG 20211120 112047782 XL
After welding the broken frame tube, my buddy cut some sections of DOM tubing to brace the previous broken section. He did this for the remaining 3 cracked tubes.
IMG 20211120 112622958 XL
IMG 20211120 120524435 XL
Scoop
Scoop
5,438
21,385
  3. Talon R LV
Threads like this make me happy that my big brother is a welder by trade AND he also operates his own mobile welding business.
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
After removing the sway bar, I noticed that the mount had started to crack on the passenger side. This is what my buddy came up with to strengthen the sway bar mounts. He positioned the added support tube forward of any trailing arm travel.
IMG 20211120 122634167 XL
IMG 20211120 145144335 XL
Then he cut some 3/16" plate to triangulate this section.
IMG 20211120 131503009 BURST000 COVER XL
Everything was done equally to both sides.
IMG 20211120 142049166 HDR XL
Plasma cutters are so cool.
IMG 20211120 144023811 BURST000 COVER XL
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
I noticed some paint stress in these corners so a couple more plates were made up.
IMG 20211120 145247595 XL
More tubed bracing on the other side.
IMG 20211120 145254971 XL
My other buddy helping the way he knows best.
IMG 20211120 163723334 HDR XL
Good to have friends like this!
IMG 20211120 163734282 HDR XL
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
All touched up and ready for action this weekend.
IMG 20211122 111058898 XL
IMG 20211122 111119721 XL
IMG 20211122 112734766 X3
I also asked my buddy to modify my KFI hitch receiver since it's much stronger than the Dragonfire receiver that was a bolt on with the DRF bed extender/spare carrier.
IMG 20211122 112650270 HDR XL
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
Always good to be able to call in a favor when you really need it and want it done right. While I've welded a (very) little bit before, I wouldn't have been comfortable trying this repair on my own. I hope to be able to change that soon though.
Forgot about this thread..... My buddy with the previously uncracked stock frame had his crack just like all the other ones pictured here a few weeks ago.
Show him my pics, hopefully he knows how to weld or has a good friend that does!
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
One of my options was to go through my insurance to have the frame replaced but then I'd still have a new frame that would need reinforcing. Another would have been to find a fabricator willing to fix things they way I wanted, only one person got back to me and the conversation wasn't too confidence inspiring. My buddy was my best option but I had to wait a bit for him to be available. For me, it was worth the wait.
212,817
Just like it should have come from Honda factory!
prostreet66mustang
prostreet66mustang
Oro Valley (Tucson) Az
I just got mine back from fab shop. I sheered off the sway bar pad that took part of one of the tubes as well. Stock frame with the Eibach bar and they do give you a good mounts. The frame shop said it was a sheer not a slow bend. It was in an off road desert race and the way it beat up the pipe and area around it must have sheered early in the race as I did not see it till I broke and new bead lock wheel that I was changing it. Sorting out what will take the racing. Picture is after the fix. If you are running that hard check your front upper A arms. They are a weak point and you will see the upper arm bends up. Was a bummer I really like the course.
20211123 063919 HDR
