Sheetmetalfab
Yeah my upper A arms are bent up.I just got mine back from fab shop. I sheered off the sway bar pad that took part of one of the tubes as well. Stock frame with the Eibach bar and they do give you a good mounts. The frame shop said it was a sheer not a slow bend. It was in an off road desert race and the way it beat up the pipe and area around it must have sheered early in the race as I did not see it till I broke and new bead lock wheel that I was changing it. Sorting out what will take the racing. Picture is after the fix. If you are running that hard check your front upper A arms. They are a weak point and you will see the upper arm bends up. Was a bummer I really like the course.
L&W fab quit building the Talon x upper A arms.
i already have the lowers and have no desire to put forward A arms on an x4 because of turning radius.
