2020 Honda Pioneer 1000-3 Flashing Error Code
A
Alpisha
5
South Dakota
Hello. I'm having some trouble identifying an error code on a 2020 Honda Pioneer 1000-3 we just bought. It was a demo rig, but it had under 25 miles on it. A number "1" flashes 5 long times and 2 short. The side by side will still shift into high, low, reverse, etc., but the Pioneer will not shift out of first gear. The engine seems to have a hard time running, as well (sound is a bit high-pitched). Trying to change from automatic transmission to manual transmission doesn't change anything, and changing from turf to 4-wheel drive didn't help either. Does anyone know what's wrong? I just want to know if this is something I can fix myself or if it is an electronic issue that will require a dealer.
Reactions: TripleB
Hillbillytnt
Hillbillytnt
552
2,030
Ky
Same thing happened to mine. The connection is just held with tension so it came lose a couple of times until I got it tight enough.
Reactions: ChadD and TripleB
