Talon 2020 Talon Quick Specs Comparison.
209,918
I
The Turbo appears to be an accessory add-on available in the Fall for almost $6k.
Plus Installation ofcourse!!
If I'll to have a turbo, I'll go RZR! Thank you at $ 6,000.00. P1 looks better all the time!
280,197
So is there a factory Turbo Talon or not?
Note the business card in below picture. It says Jackson Racing, Honda Talon Turbo. I suspect that it will be offered as an official or HRC accessory option.
Resized 20190603 135252 768x1024
What you’re looking at is a Honda Accessories turbo kit developed by Jackson Racing. If you’ve spent any time in the sport compact world you know these guys have been doing this for decades and they don’t play around.
The highlights:
  • GT17 Garrett Turbo delivers approximately 165 hp at 8psi on 91 Octane
  • NO engine modifications necessary
  • NO welding / fabrication necessary, direct bolt-on
  • Uses stock fuel pump
  • Jackson Racing ECU tuner is used to flash ECU. Shifting changes are available for various tire sizes up to 32″
  • TIG welded 0.120″ wall stainless turbo manifold for durability
  • CAD designed cast aluminum intercooler tanks (air-to-air w/ electric fan) and intake
  • 50-state emissions compliant
Pretty sure it's on the modded 4 seat chassis setup as a 2 seat racer.
132662 ce1440a2ea059e6d08de8fbaf7f72847
209,918
Note the business card in below picture. It says Jackson Racing, Honda Talon Turbo. I suspect that it will be offered as an HRC accessory option.
Pretty sure it's on the modded 4 seat chassis setup as a 2 seat racer.View attachment 133572
And so you have pre ordered? HA! Turbo Bob, that's catchy! HA! If I had a right mind I can't understand why any one would want a turbo unless riding the dunes. ???????????
Sandfreak
23
Oregon
Don't know why a turbo is needed, unless you ride the dunes.
I don't ride the the dunes just desert with my stage III180hp turbo X3. Turbo is a must for how we ride.
Sandfreak
23
Oregon
Am I correct that launch control isn't available on the two seat Talon?
280,197
Yet, they aren't finished announcing models. Gotta fill all those 2019 dealer orders before you drop the 2020 obsolescence bomb on them.
Reactions: CumminsPusher
209,918
Didn't think about the Deserts!
Fl-Cracker
Fl-Cracker
42
86
Fl
Just wondering since the talon and p1k are the same engine platform would this bolt on a p1k because I need turbo power
67,900
No.
Muffler and what nots are all different. Only the engine primary design is the same.
Still. If you have the cash it can be done.
