2020 Talon x4 live v wheel n tire combo?
N
NEWHEELER
elkhorn nebraska
  1. Talon X4
Hi All...My first post on this site.. coming from the artic cat side i bought a 20 Talon x4 live v, trying to stay the same factory front width 64" as close as possible looking at K2 Bajas with sti grenade beadlocks can anyone tell me what offset will keep factory front 64" and not over and still be able to use same offset in rear? Alot of trails we ride in the Black Hills have 64" max width. Thanks for any help on this!
Steve M.
Reactions: TripleB
208,728
Steve M.
Call the wheel MGF, they can give you an answer in a heart beat!
Sheetmetalfab
Sheetmetalfab
2,224
14,011
Alaska
Steve M.
With system 3 wheels and 9.5” wide tires.
6-1 front 4-3 rear
Reactions: volkspower
PaulF
PaulF
1,462
4,815
Steve M.
No matter what you purchase, you will be at least 1" wider up front. Reasons...
The stock front wheels are only 6.5" wide with a 50mm offset. The closest offset you can get is the STI 7" wide with a 50mm offset (don't go by the X+Y offset, it is completely inaccurate). This will make you 1/2" wider to start with.
Stock tires are only 8.7" wide. The narrowest tire you can find is probably 9.5" but limited in choice. This will make you another ~1/2 wide up front.
6-1 front 4-3 rear
System 3 6+1 are only 45 mm offset so this combo will net you...
65.2" wide up front.
64.3" wide in the rear.
Reactions: CID
Sheetmetalfab
Sheetmetalfab
2,224
14,011
Alaska
Except it measured exactly 64” front and rear with that combo.
I trust my tape measure.........
