P1000 2020 went splash
bullyx
149
450
new york
How tender is a pioneer is my question. Went thru a few water crossings, not above tires, perhaps a little too fast and the kidos and myself were soaked, lol. Got home, cleaned her good, took hood off to inspect and the white "filter" was damp. Took out and there was a little water spots in hose. Wiped all down, filter dried in a few min.
One reads the bad here and there, but is the pioneer really that fragile?? Going for service in a week. Wait to have oil changed before running again,? Rig was not submerged, just a good splash.
Thanks all.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Just check the airbox behind the seat and make sure its dry. Check the dipstick back there as well but odds are if you made it home you're probably fine. The intake tube wont show much water at home because it dried itself on the way. Just check the actual air filter to be sure its dry.
bullyx
149
450
new york
Thanks!!!
Reactions: BWAF
JimmyA
JimmyA
1,644
5,504
Northeast texas
Pull the crankcase oil stick just in case and probably wouldn't hurt to check the front and rear diff, pretty simple to do!
Reactions: Jdtc and bullyx
