P700 2021 700 deluxe dies while driving
43,590
I add one directly off the negative post on the battery to the frame, another from the engine to a spot above the existing main ground cluster on the frame.
You need to add some directly to the ecm grounds just down from the connector to the ecm. There should be 3. The ecm is what's flipping out here, and I suspect the grounding to it is the issue. Personally, I wouldn't go directly to the battery negative (I read somewhere that this wasn't recommended), but down on the frame, preferably the rear half where the existing grounds have good contact. I combined all 3 into 1 eyelet, and used a nut on the backside of one of the existing ground bolts.
What you've done isn't a bad ideal IMO, but it doesn't really address the potential that the ground path to the ecm is janky.
Mine could do it tomorrow...but enough time has passed that I'm calling it fixed. For the record, I still have only the factory ground cable from the battery, though I'd like to add more...
WagginTail
WagginTail
1,656
6,075
SC
@Slackjaw should do this also
Jedarious
22
40
Central WV
30 miles later and it started puking again. I got a new battery today, I’ll install it and root around on some wiring tomorrow.
Slackjaw
Slackjaw
294
462
Durham NC
Have you replaced your headlights?
I'm birddogging a theory.
Jedarious
22
40
Central WV
No, have not replaced headlights. Here is another wiring diagram for 2021 700.
  • ML.RVX34spx.HL31423024005A.pdf
Jedarious
22
40
Central WV
When my machine does a hard downshift before it dies has me thinking it has to do with the electronic shifting on my deluxe model. Does this dying problem occur on non deluxe machines?
Jedarious
22
40
Central WV
Two weeks since I replace stock battery with a larger ( physical size ) one with higher CCAs. This morning it is 16° and for the first time ever my pioneer started right up at this low temperature! Also; It has not died on me since the replacement. I’m hoping that I have resolved two issue at once, but I’m not convinced about the dying bit being permanent quite yet.
Jedarious
22
40
Central WV
Just an added note, the stock battery Honda put into my Pioneer 700 was the same size battery they put into my 2004 2 wheel drive Honda Rancher. How can they think a 4 wheel drive side by side with ES + EPS and an engine twice the size of the Rancher will function properly with the same battery?
Jerryg
Jerryg
12,272
96,760
NEPA
That's a good question for the engineers of the Pioneer but my guess it's a money thing.
Reactions: Remington
