2022 Honda pioneer 1000-3 OEM switches
A
A_hembree00
I bought a 2022 Honda pioneer 1000-3 deluxe , and have slowly been installing accessories and finally decided to look into the oem accessory switches and can’t seem to find any info on how you hook accessories to them , nothing in the manual and I can’t seem to find anyone that’s done any videos on them , if any could give me some advice or guidance I’d really appreciate it!
67,231
Look for blue tape under the hood, under the dash along the main wire harness.
There should be 2 spots with blue tape on the Deluxe and Trail models.
Forest and Base only has the one above the primary battery.
One to the passenger side...
Above where ppl install the second battery is what you are looking for.
Inside the tape is a wire loop. 1 for the Trail model and 3 for the Deluxe model.
This is your feed and fed wire.
We have extensions in the store.
One wire is power IN from a source (battery or other).
The second wire is power OUT to the accessory.
You will need to find a ground for your accessory.
Also, these are rated for 3 amps max.
So recommend small accessories or to trigger a relay.
Blue tape above the primary battery is a key-on connector. We sell a harness for this as well.
67,231
The Deluxe model will have 3 wires here.
The trail model will have 1 wire
1659404724611
1659404684506
