21 Talon i4wd not working
Sxsguy1991
7
20
NC
I have an issue that is causing me to pull my hair out.
2wd/i4wd switch does nothing
Dash stays with locked 2wd
Diagram will not change or register.
It was working when I unloaded it and washed it 2 weeks ago, then the cat bumped the key and the battery drained, I installed the Guage relocation kit and then charged the battery back up.I have no warning lights. I have checked and re checked all connections and fuses. Could this of been caused by the dead battery and now it’s locked out?
HUCK
HUCK
1,047
2,319
ARIZONA
Get rid of the cat ! Get a DOG
PaulF
PaulF
1,462
4,814
Have you driven it faster than 19 mph since the battery went dead? If not, do so for a little bit and see if that helps.
906UP
906UP
14,270
135,338
da Yoop
Maybe these will help.
  • I4wd_1.pdf
  • i4wd_2.pdf
Reactions: Blownzuki and CID
popeye
popeye
3,275
14,644
kapowsin, Wa
I know low voltage will make it not work, I did the same once, left the key on over night, the next morning it would only blink back and forth between 2 and 4 on the instrument cluster, and the i4wd drive light was on, I just drove it for a bit and at some point it turned itself off
Sxsguy1991
7
20
NC
So far I don’t have the i4wd warning light nor will the dash indicate 4wdjust stays on 2wd lock.
we have swapped the switch with one from a working talon with no changed, have ohmed out connections and everything appears fine. I don’t have any power at the front diff (green connector) on either wire with switch turned to 4wd. Slowly chipping away over here 😂
PaulF
PaulF
1,462
4,814
Make sure you are doing all your testing with the engine running. 4WD does nothing with KOEO.
Reactions: Blownzuki and BPINE
Sxsguy1991
7
20
NC
Got it fixed the blue wire in the main harness was pulled apart somehow I’m not sure, I think when I cut the tape to separate the winch power wires somehow I maybe cut the blue wire only threw the loom.
63BA2FB5 A9F3 4C38 AADC F4CC60319A42
NTCPrezJB
NTCPrezJB
Retiring Member
108,766
959,436
Hidden
I’m glad you found it and updated the thread. Enjoy it!
5,425
24,913
