P1000 29" tires on factory pioneer 1000-3
catvguy1986
Peculiar MO
Hello,
I have a 2020 Honda Pioneer 1000-3 it came with 27" tires on it.....Can I put 29" tires on it with the stock wheels? Want to make sure no rubbing, etc.
So tire sizes would be 29x11r14 & 29x9r14
THX
Reactions: Lady01
Lochsa88
Lochsa88
44
154
have heard true 29 will rub a little. Several threads on this topic, and what wheel offset you need if change. i went to 28x10x14 (carnivores) on all four corners, so i can rotate. bought tusk wheels from Rocky Mtn and had shipped with tires mounted. and i didnt add the spacers some suggest, not needed. i prefer to keep tire under fender and extended flares (mudbusters).
Soaz1000
Soaz1000
164
893
Soaz
Depends on the actual height of the tires. Some tires run smaller than sized. If your suspention is stock a better choice is 28" If you plan on running a aftermarket skid plate there is usually a lip that turns up at the bottom of the wheel well. 29" won't fit unless you trim and run forward arched A arms.
Robobrainiac
Robobrainiac
2,551
8,963
32s on a stock pioneer could fit in a straight line..
As others have said a true 29 will rub. If you want bigger tires grab some forward arms and send it.
Reactions: Lady01 and JenElio
115,793
I am running 29’’ tires on stock wheels and have not had any trouble. I think I could get away with 30’’.
Your joking right? 🤣
better get that tape measure out, I bet them 29‘s measure out as 28’s
Unless u have some other mods to help this? If its true #POIDH.
A
aandersonpa
39
Depends on the tire. I put on System 3 xtr 370 28x10x14 on stock rims and have barely a finger width-space at full turn and half compression. Tires measure true 28 mounted.
Reactions: Lady01
