Does anyone have a picture you could share if you have a 10 inch tire on the rear stock 14” rims? The stock tire is 11 wide, and I’m worried going 10 wide won’t be enough. Fronts are no worry. Thanks!!
I think I read about someone trying that and they didnt like how exposed the rim was (not enough side wall protection).Does anyone have a picture you could share if you have a 10 inch tire on the rear stock 14” rims? The stock tire is 11 wide, and I’m worried going 10 wide won’t be enough. Fronts are no worry. Thanks!!
I can’t find blackwater Evo’s in 30x11x14 or is prolly go that route. They only come in 30x10x14. What about four fronts all around with 30x10x14? Anyone have a pic of that?R u wanting 10s all around for rotation purposes. If not id go a lil bit wider on rears (protection and looks) the fronts will look like the tire is eating up the rim compared to rear
Mine are 28x10x12 evos on the stock 12 inch steel wheels. I don't know if that will really help u, it being different size tires and wheels. I have a 1 inch spacer on the front and 2 inch on the rear. But I really only needed the 1 inch on the rear to even it out.Thank you! Pics would be great, as I DO have access to two more fronts, and have some spacers already from RB3
Nah you'll be fine. I run 10s all around and 11s. In fact I'm not sure theres a 30" tire that is 11 wide.Does anyone have a picture you could share if you have a 10 inch tire on the rear stock 14” rims? The stock tire is 11 wide, and I’m worried going 10 wide won’t be enough. Fronts are no worry. Thanks!!
Thank you!!Nah you'll be fine. I run 10s all around and 11s. In fact I'm not sure theres a 30" tire that is 11 wide.
