32s installed on Talon 1000x4 live valve
Many_Gs
Many_Gs
217
517
PA
  1. Talon X4
Gained about 2" of ground clearance over stock with the upgrade. I was bottoming out a lot and this was the upgrade I needed. Overall happy with it, though I can definitely feel the power change. It's not as snappy as it was with 28s but that's okay. I prefer ground clearance and not having to worry about bottoming out! 32" terrabites.
484276bd03de472c874f382c70473ea6C4145abe611ae5a3de6bd885f8c3b995
Sent from my SM-N975U using Tapatalk
F1d3c042add67b0e8ad4abc1a939704d
69,054
View attachment 282690View attachment 282691
Looks great !
Reactions: BWAF and TripleB
Many_Gs
Many_Gs
217
517
PA
  1. Talon X4
Looks great !
Thank you, I'm happy with it so far. Those tree kickers added a good bit of weight, but one of my best purchases so far. We'll test out the tires tomorrow and see how they do!
Many_Gs
Many_Gs
217
517
PA
  1. Talon X4
Update: pulling out of my garage I felt the front tire rub against the inner wheel well. Just barely but she rubbed under full lock. May have to shave down the wheel well, not sure what else I can do.
Will changing the A arms be beneficial in any way? Stronger I would imagine, what other benefits are there?
Reactions: BWAF
PaulF
PaulF
1,462
4,814
32's on an X is a well known rubbing problem and will get worse as the suspension compresses.
Never heard of shaving down the wheel well. If you end up doing that, let us know if that works.
If you install the Super ATV forward swept A-Arms, it will fix the rubbing and provide a little more A-Arm to ground clearance.
Hit up @SuperATV for a discount code.
L
lifeisgoodsteve
118
256
Bitterroot Valley, MT
I also added the superatv control arms on my X4 LV with BFG KM# 32's and it's been clear sailing without any rubs that I've been aware of.
