That's awesome!It took about 5 tries, but I finally got it right. No two edges on that darn warning label are parallel or perpendicular. lol I attached it with stainless 4mm button head screws and lock nuts. Now, I just need to cut a hole in my dash and start wiring.
View attachment 102683 View attachment 102684
He could buy a glove box , remove the door from it and replace it with his switch panelNice work, but where you going to put the @Chooglin glove box?
Good point!Nice work, but where you going to put the @Chooglin glove box?
Hinged???He could buy a glove box , remove the door from it and replace it with his switch panel
Still have the .STL?Long term, the PLA filament I used to print didn't hold up. It warped in the hot sun. I'm thinking ABS would be the right material to use. I ended up making an aluminum switch panel. I'll try again when I get some ABS.
If I get a minute, I'll post the STL on thingiverse and post a link for others that want to give it a try.
The final product looks great. Definitely worth the effort.It took about 5 tries, but I finally got it right. No two edges on that darn warning label are parallel or perpendicular. lol I attached it with stainless 4mm button head screws and lock nuts. Now, I just need to cut a hole in my dash and start wiring.
What about PETG?Long term, the PLA filament I used to print didn't hold up. It warped in the hot sun. I'm thinking ABS would be the right material to use. I ended up making an aluminum switch panel. I'll try again when I get some ABS.
I feel your pain. Seems like nothing is square with anything else on these machines! That's why for my business projects I invested in my 3D scanner. First project with it is my front seat Milwaukee packout mount and it's very acurate. Frustrating to learn how to use but I got it now. We use a Faro at work for industrial projects so I had a little knowledge of how this works already. For a totally new to scanning person, this would be mega frustrating!!It took about 5 tries, but I finally got it right. No two edges on that darn warning label are parallel or perpendicular. lol I attached it with stainless 4mm button head screws and lock nuts. Now, I just need to cut a hole in my dash and start wiring.
