P700 4 point harness install
Tflynn
Tflynn
Not a liberal
2,501
3,834
Northern California
I got a chance to install my new 4 point harness's today. This is a REALLY easy mod with no cutting or welding required! I was unable to locate model specific units so I took @JACKAL 's advice and bought Beard harness's for a 2012 RZR 800. Thank you Jackal! They work perfectly.
First thing to do is remove the old belts. Four 14mm bolts and you're done! Next remove the seat pan so you can take off the buckles in the center of the bench.
Once those are out of the way bolt the lap belt on the new harness in the factory locations.
Center-
And side-
Once you have the lap belts bolted up you can reinstall the seat pan and seat. Should have this-
Now the shoulder straps. These come with a buckle and mounting plate I guess you'd call it.
So what I did was remove the mounting plate thing and use the buckle on the cage-
This puts the shoulder straps right even with my shoulder. Technically they should be around 4" below my shoulder but I'm ok with this setup. Still better than stock belts! If I chop the top I'll add a lower bar for the shoulder strap but for now I'm good with this.
An added benefit from removing the stock belts is it makes a perfect spot to run a snorkel-
Those look good! How do they feel
68,409
Excellent @Tflynn, Doesn't look too complicated either.
Tflynn
Tflynn
Not a liberal
2,501
3,834
Northern California
They definitely hold you in place, I could tell that right away. Once adjusted properly you start to forget they are there like with any seatbelt. Im planning to put some miles on them this weekend, then I'll have a better opinion.
Reactions: CumminsPusher
Tflynn
Tflynn
Not a liberal
2,501
3,834
Northern California
Nope easier than an oil change really. Not sure of the configuration of the 1000's cage but you could probably do an almost identical setup on a 1000 if you were so inclined. By the way these harness's are $90 a piece, so for $180 you can add a lot of safety to your ride
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Just a teaser @Tflynn, adding the Beard 4 points to my rig. When I'm finished I'll post a step by step of the shoulder mounting bracket I fabed up. Waiting for the darn paint to dry
Tflynn
Tflynn
Not a liberal
2,501
3,834
Northern California
Looking forward to seeing what you've done. After the last couple rides I decided I need a better way to mount the shoulder straps
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Here's a couple of pics.
20160828 131338
20160828 102355
20160828 103627
20160828 095744
20160828 132133
20160828 133029
Then I had a problem with the inside shoulder belt slipping down, so I added a tube across between the headrest
20160828 153235
20160828 153304
Couldn't wait for the paint to dry. So guess I'll sand and respray later.
Sent from my SAMSUNG-SM-N930A using Tapatalk
Reactions: Eltobgi and Tflynn
Tflynn
Tflynn
Not a liberal
2,501
3,834
Northern California
Nice work! And as for letting paint dry, it's one of the hardest things for me to do too!
Reactions: Tramguage1
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
20160828 154633
I don't do waiting well. I did unload 15 bags of ready mix and had a beer. That still wasn't enough time
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Why are my pics turning sideway!!!!!
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
One thing I would do differently is drill two 3/4 holes in the plate that the buckles bolt to. It was tough to get the seat bolts back in.
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
@BIGRACK The boss should be good for the next ride!
Reactions: BIGRACK
BIGRACK
BIGRACK
202
376
Dayton Tenn
MmThe harness look Google and will serve you
I like the harness mod you are doing The boss and I have been thinking about adding a set to ours. As you know us so called seniors are pretty daringLOL
KyleC
KyleC
102
155
Pittsburgh, PA
I know this thread is old, but do yinz remember the part number for these harness’s by chance? 2012 RZR is 880-220-02 on Rocky Mtn. Just want to verify before I order.
