P1000 4 wheel drive issue
Chris200
5
5
Troy mo
Ok need some help. I have a 2018 Honda pioneer 1000-5le. Im not sure what is going on it will not switch from turf mode to 2 wheel dif lock to 4 wheel. It’s stuck in turf mode. I watched some you tube videos on how to adjust linkage from turf to 2 wheel so that’s not the issue. Anyone have any idea what else to check?
BigOL3
BigOL3
2,994
8,920
When you have a problem, are you referring to it simply not showing engaged on dash when the lever moves ..... or ..... does it fail to indicate on dash even after traveling over 100ft?
Chris200
5
5
Troy mo
It fails to indicate on dash. Plus I drove around my driveway and it is not engaging out of turf mode because wheels are not locking for sure when put in 2dif lock.
