My kid wacked a rock and sliced the inside wall of the front tire. Rock rash on the bottom of the A-arm and a slight bend. Too much damage/bend to keep riding or you think it’ll be fine? I’m rarely over 35 mph or on pavement.
Ha, you sound like my neighbor! Except for the fact that he would have wanted to use my garage and tools. Oh did I mention and my hands to do it too? That's OK, he brings beer.I might ride that forever or until I came up with the energy to remove it and have my neighbor push it straight in his press, Check yer toe-in tho.
Bad idea on the winch, too easy to kink the tube or over bend and cause more issues.sounds like a lot of experience saying it will be OK.
FWIW
maybe keep an eye on the front bolt and bushing
make sure it doesnt wear out and damage the attachment point/frame.
you can see in the pic how cocked it is vs the rear
you have a winch and snatch block?
with the right anchor points (trees), you may be able to pull it close to back in line pretty easy
You will be just fine, go enjoy.Thanks guys. Nothing else appears damaged or bent including the mounting points. I’m gonna ride it once I get a new set of tires mounted up on Monday and then keep an eye on it with alignment, etc
