P500 A little differant take on doors
rocmar
rocmar
4,741
5,773
4 CORNERS
Those other states must not have trees.
We don't have alot...
in certain places...
but the Ponderosa Pine
national Forest...is Loaded.
There's a town / city in West
....Texas called "No Trees"
City Ordinance. ...you can't plant
any.
157,040
View attachment 30496 View attachment 30497 View attachment 30498 View attachment 30495 Today I made doors out of some 1/4 plastic I had left over from making the rear seats,I don't want to take anything away from Jak ,I think the doors he makes are a great idea,I just wanted something simple and functional for me that fit inside the roll cage so I wouldn't have to worry about catching them on anything.I also didn't want them to come in contact any where on the sxs ,I can't stand rattle's and vibration, I'm not saying the doors jak makes do,I just know mine don't,I used a piano hinge, and a 3/8" chain link cut in 1/2 for the latch
Been staring at these pics a little more and getting my own ideas with the doors. You say that you used 1/4" plastic, is that rigid enough or should I go thicker? Also, is the plastic textured at all or just smooth? I just want to know, cost aside, what is the best stuff to use?
iowaguy
iowaguy
624
1,424
Eastern Iowa
I used HMWPE plastic that comes in rolls, It's a b**** to work with,I had to heat it to get it to lay flat, It is what is used in the bottom of dump trucks, It is plenty heavy enough, You might want to make some type of frame on the inside of the door if you wanted to hold it ridged but the way mine is now if it gets hit with anything it will spring back, your not going to hurt this stuff .It is smooth on both sides,I am planning to spray it with bedliner or plastic dip when the weather warms up
Reactions: trigger and rocmar
157,040
I'm considering 3/16" aluminum too. Wouldn't need to be bent, so that's a bonus, just cut and fastened.
I wondered if yours was very rigid with no frame behind it? The way I'm looking at doing these doors wouldn't require a frame.
Reactions: iowaguy
Ha, we've got plenty. I still as a personal preference don't like the nets. But I appreciate those who do and even repurposed mine to someone who does and needs some for the kiddos.
iowaguy
iowaguy
624
1,424
Eastern Iowa
This plastic is also available in sheet form,I just bought this roll end cheap.It was 4'x14' for less than $100.00
