Talon A pillar light pod mounts
SpeedBuggy
SpeedBuggy
1,289
10,214
WA
I was wondering if anyone knew where to find A pillar brackets for light pods. I’m having trouble finding some that fit the recessed bolts on the ROPS bar. I have a front window and want to stay away from clamp style mounts. Here are the lights I am looking to mount up
56E0D859 D1B3 42DE A033 2809B3267EF0
thanks
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
I found those at Tractor Supply.
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
I know it would be a long shot but you you could try rockymountainatv tusk mirrors brackets for Talon. see if they would sell you the brackets
SpeedBuggy
SpeedBuggy
1,289
10,214
WA
I ordered these. A little pricey but they look like quality pieces. I’ll post a pic once they arrive and I get the lights mounted
8BD2261C 3A3A 4C65 8ABB BBA80BAD4030
SpeedBuggy
SpeedBuggy
1,289
10,214
WA
Let us know if those work
I received the light brackets yesterday. Good news/ bad news. The good news is they will work on the Talon. The bad news is they are too close to the ROPS A-pillar to work if you have a windshield in place. I have the Honda OEM plastic window and plan to run the shorty in the summer. I can see two possible solutions to use them with a windshield. Option one and what I plan to try first is to grind the spot welds on the spacers on the brackets so that they can be flipped to the opposite side and move the light outside the window. This will allow the window to be removed. Option two is to cut the bracket and add an inch to make it stick out past the window. I'm spending way to much time and money on these stupid brackets but, I really want the A-pillar lights to complete my lighting. For being a popular mounting location I am surprised the options are so limited.
also, the brackets did not come with the laser-etched branding as advertised but I could care less about that part. They are pretty stout and a good product overall.
Bracket
Reactions: IDIOT
SpeedBuggy
SpeedBuggy
1,289
10,214
WA
Update. The bolts included are bigger diameter so new bolts from the hardware are needed. And the spacer is about 1/8” to short. The plate also won’t allow the funky Honda window bracket to fit in the outer channel. I wasted 50 bucks on these so I’m going to cut and grind a little more to see if I can make them work.
SpeedBuggy
SpeedBuggy
1,289
10,214
WA
After I go for a ride
Reactions: CID and stellarpod
IDIOT
IDIOT
280
755
Kingman, Az.
Damn i want to run A-pillar lights with my half wind shield, hope you get it fiqured out SpeedBuggy
SpeedBuggy
SpeedBuggy
1,289
10,214
WA
I ended up cutting down the bracket, moving the spacer and flipping them outside the window. I wouldn’t recommend using this method, but I spent $50 on these brackets and was able to use them with some modifications. It’s the OEM windshield clips that make it a challenge.
68E21FD1 1E2A 4734 A847 07068CA90C70
2C736BBB C797 4084 B7C6 6F5D0C6ED842
8BC517DB A97D 4AD7 ABF3 C9D1D16DC350
DB728B63 B11F 4E9A 9A0F E0C3F217D9F6
C44AF358 1C78 41E9 B09A 6FEC40E7188B
BAA1B3B7 7E58 4728 BAB5 9F6B0B06B0DA
SuperMario
WV
Bosman Designs Extended Lower A-Pillar Light Mounts 2019-2021 Honda Talon
They offer 2 types. This is the extended version to fit with the Honda OEM full windshield. Side note. The Rigid lights are more expensive than others in the same category but they are extremely bright and very satisfied with them. Made in USA
IMG 4134
IMG 8742
Reactions: SpeedBuggy
sspeederr
sspeederr
391
661
I ran into something similar i ended up making my own outta scrap metal to work with satv window
20200608 120409 20200608 120323 20200608 120554 20200608 171924
