Robobrainiac
I don't have alot of friends. I have even less intelligent ones. I view you group of guys as a smart bunch of great people and at the lack of my willingness to want to use the internet to find a different forum to post on I would like the permission to post a question here.
Long story short my wife owns a cleaning company and we are expanding. I am retrofitting a GM 16 passenger van into a sweet commercial cleaning capable machine. My plan is to have shelving in the back, a water holding tank with pump, a station to charge all cordless tools, an air compressor, and lastly a power bank to power all this fun stuff. The items listed would most likely be used rarely with the vehicle not running. So the power source will mainly be supplied by the van while in travel. When parked overnight at the office I plan to have it plugged in to a battery maintainer. So my main question is verifying I have the correct items chosen to make all this happen. I have never done any auxillary battery installs prior to my pioneer and I see there are alot of talented and intelligent people on here so I would love to get some input.
The water holding tank pump is nothing special. It will be a standard 12v siphon type pump.
The cordless tools will consist of 2 ryobi 18v chargers, 1 Milwaukee M12 charger, 1 56v worx charger, and 1 40v Hoover charger. I am not sure of all the power demands of each charger at the moment. I would have to go down to the shed and check them all out to know for sure.
The air compressors I am stuck between are these 2
The main function of the air compressor is to blow out vacuum filters and potentially a hose ran into a building to clean screens. I like the thought of the higher SCFM and they both seem decent. I am considering the smaller one only to save space. I do not know a lot about air compressors so I am not sure if the bigger one is better or would last longer between motor cycles.
Lastly a Karcher cordless floor scrubber would be charging on this system as well.
I assume I need an isolator for the van itself.
The power source I have picked out is a 2000 watt pure sine inverter and a 200AH deep cycle battery.
5 Gallon , 225 PSI High Performance Wheeled Jobsite Air Compressor
Amazing deals on this 5G 225Psi Oilfree Air Compressor at Harbor Freight. Quality tools & low prices.
www.harborfreight.com
27 Gallon , 200 PSI High-Performance Vertical Shop/Auto Air Compressor
Amazing deals on this 27Gal 200Psi Hp Shop/Auto Air Compressor at Harbor Freight. Quality tools & low prices.
