AED Fabrication and Design Talon Rear Gate
Scoop
Scoop
5,399
21,257
  3. Talon R LV
Actual work time I’m not sure. He said once he got the angles and cuts figured out it would go pretty quickly. I’m sure he has a plan moving forward as he noted all the angles and lengths.
Out of curiosity did you happen to ask him about adding a tire carrier?
282,989
Now I’m paranoid!
If it does hold (probably will) your rear tires may be off the ground, hope the front pulls hard enough to un-catch it from rock ledge. I've seen this happed to a couple of Pioneer 1000's with those swinging bed extenders, in those cases 4WD did pull them off the ledges.
Vikes79
Vikes79
SKOL!
12,000
115,409
South Dakota
  2. Talon X4 LV
I considered fabricating one up for my Talon x4 out of aluminum just like I did on my P1k5 until I took the X4 on a week of rides in the Badlands and Black Hills.
With just essentially a plastic trunk locker filled with basic tools, tire kit, first aid items, plus a gallon of gas and a small cooler it definitely made the buggy wallow a lot more than I expected. 600 lbs of capacity is not a lot.
It’s definitely nice work for sure. Be careful not to overload it and get too much exterior hanging weight.
Safety nanny out…
GovtMule
GovtMule
21,849
186,676
Tennessee
Safety nanny out…
It’ll just be a cooler or another storage box for the “essential” item that I always carry with me. Nothing overly heavy.
The Green Goat
The Green Goat
2,409
17,754
Ohio
A Yeti 45 holds 54 cans x 13oz each = ~44lb + 25lb cooler weight + ice = you good. Hell, pack two.
GovtMule
GovtMule
21,849
186,676
Tennessee
I believe you are right.
Pretty stout.
IMG 5737
