bobbyhill
Junior Moderator
Engine Type Liquid-cooled 4-stroke 8-valve Parallel Twin with 270° crank and Unicam
Engine Displacement 998cc
Bore x Stroke 92.0 x 75.1 mm
Clutch Wet, multi-plate with coil springs, aluminum cam assist and slipper clutch
Final Drive O-ring sealed chain
Gearbox/Transmission Type Constant mesh 6-speed manual / 6-speed DCT with on- and off-road riding modes
Honda Selectable Torque Control System (HSTC) HSTC 3-levels + switch-off (DCT/ABS model only, not on STD model)
Frame Type Steel semi-double cradle type with high-tensile strength steel rear sub-frame
Turning Radius 8’2″
Curb Weight 503 lb. (STD), 534 lb. (DCT/ABS)
Fuel Capacity 4.96 gallons
Length x Width x Height 91.9 x 34.4 x 58.1 inches (STD), 91.9 x 36.6 x 58.1 inches (DCT/ABS)
Wheelbase 62.0 inches
Seat Height (STD position / Low position) 34.3/33.5 inches
Ground Clearance 9.8 inches
ABS system type ABS 2-channel with rear ABS off switch (DCT/ABS model only, not on STD model)
Front Brakes 310mm dual wave floating hydraulic disc with aluminum hub and radial fit 4-piston calipers and sintered metal pads
Rear Brake 256mm wave hydraulic disc with 2-piston caliper and sintered metal pads. Also Lever-Lock Type Parking Brake System on DCT/ABS model
Front Wheel Wire spoke with aluminum rim
Rear Wheel Wire spoke with aluminum rim
Front Rim Size 21M/C x MT2.15
Rear Rim Size 18M/C x MT4.00
Front Tire 90/90-R21 tube type
Rear Tire 150/70-R18 tube type
Turning Radius 8’2″
