P1000 Aligning Front tires, what's the best way to do it.
104,777
When Crunchy got crunched, we had to turn there tie rod. Not that the break has been welded both tires seem to be out of alignment. Which way do I turn the tie rods and what's the best way to align the tires? Also, should they point slightly in, out or be absolutely straight? Thanks
Neohio
Neohio
Beast of the East
14,504
72,710
Painesville Ohio
Pointed straight or slightly in.
Reactions: DDDonkey
DDDonkey
Most recommend toe in 1/8" total. There are many ways to to align the buggy, some use the string method, I have used toe plates, and most recently I used some scrap angle, bolted to the hub and measured that way.
59,670
Tightening the tie-rod will cause the front of the wheel to toe out (front pointed outward), loosening the tie-rod causes toe-in (front pointed inward). You're basically "pushing" or "pulling" on the steering knuckle by tightening/loosening the tie-rod. If you were driving a race car (and didn't care about tire wear) you'd want a little bit of toe out to help with initial turn-in/steering through corners. The opposite is true for toe-in, you sacrifice some initial corner entry/turn-in for stability. You're driving a farm buggy through the woods and you don't want super snappy steering, so straight or slight toe-in is what you're after.
59,670
We only adjusted your passenger side tie-rod, so you should be able to get it pretty close by setting your steering wheel straight and then adjusting that side so that it's close.
Reactions: CumminsPusher
t-bear
t-bear
NE OK
Yep I used the string method from advice here. Super easy and was able to correct a toe out issue of over 1/8"! It had chewed up my front driver inside tread something good.
All looks great now!
ADVICE - use a paint pen to mark the tie rod nut-to-rod after you adjust the nut. This way you can visibly check if your tie rod nut/rod has loosened.
Reactions: Mudwing
