P1000 Anyone add cargo bed tie downs?
TimG
TimG
OLD SKOOL
792
3,966
Southern Indiana
The one in each corner is ok. The bed is mostly plastic, so I wonder if anyone has added any additional tie down. Even gun/bow racks etc, do you just screw them into the plastic. :oops:
I put a couple eye bolts in the front of my bed about 10 inches back on each side to secure my tool box. I drilled thru the bed put washers and nuts on the under side. Works great just make sure there is nothing under the bed you would drill into or bolts will interfere with.
TripleB
TripleB
14,124
123,673
Caryville, Tennessee
Dirty machine and crappy pic but I put these on every bed screw. They're very convenient.
BigB_P1K_Rider
6
10
Richmond ON. Canada
I struggled one what to do as I like to bring different thing depending on what type of riding I'm doing, I picked up these E-Track Rails, Cut them to fit and was able to position them that I could drill threw the bed liner on the High ribs and use 1 inch length 1/4" bolts with fender washers and nylon lock nuts underneath. now I can pretty well snap in a snap lock easily to tie down any thing, tool boxes, coolers, chain saws, spare tire, jacks etc. Total project cost less than $300 cdn
20200820 195404
20200820 195404
20200820 195404
20200820 195421
20200820 195433
20200820 195447
20200820 195504
mikeholley
mikeholley
25
90
Sonoma
I also use these on the vertical part of the bed toward the cab. 1 in every screw hole. I also used a few of the smaller ones on the bed floor of the 5 seater. Just in the places that wouldn't allow the bigger ones from the post above.
This is possibly one of the best solutions and the cheapest for adding more places to connect in the bed of the Pioneer. You can easily add multiple D-rings in minutes using the bolts in the bed without all the work of the other solutions.
Jsquared
Nashville TN
Reactions: Lady01 and TripleB
Bandman
Bandman
130
460
Hayden Lake, ID
TripleB,
I used your link, ordered the hooks, installled them and they are exactly what I needed!
Thank you!
