P1000 Anyone build their winch mount?
1BadDart
1BadDart
1,437
13,305
W. KY
I'm going to order a Superwinch Terra 45 next week and am not crazy about mounting it in the "hole" provided by the factory. My idea is to mount it up higher on the outside of the factory bumper. Anyone else done this?
Thanks, Justin
67,170
There are a handful or so of skilled people around here.
not really much room on the factory bumper without pushing it out and all in the way.
About best one I have seen with factory was a 2" hitch plate installed. Then your winch on a plate. well, that might have been for the 700.
Anyways, I liked that method because you could move it to the rear or even remove all together it if you didnt need it around the house.
Reactions: Eltobgi and JTW
You ordering from Amazon? The Terra's are on sale now... not sure how long that will last. I just ordered the EMP mount.. I like you would like it higher after having it on that strongmade bumper on the p500, I think that's a great place for it..
PS..EMP offers a forum 10% discount.
ofrcboy
ofrcboy
507
589
Oregon
Thanks, Justin
YES I built mine and installed second fairlead on the bottom for my snow plow rope goes straight down to the plow push tube.
20160613 082514 20160613 082504
Reactions: 1BadDart
1BadDart
1BadDart
1,437
13,305
W. KY
Thanks ofrcboy, I'm going to mount mine in about the same location as yours.
Reactions: ofrcboy
quickfish
quickfish
36
46
Kent, WA
I took the bumper off, went to harbor freight and bought a 12" 2" receiver tube extension cut it in half took the receiver end and some angle iron and had it welded up. Once it was welded up took and had it all rhino lined. On the other end had the winch plate welded on. Used Anderson clips on the power source so I could remove and plug into the back if need in the back
