Egay is too expensive in my opinion. Anyone on here make these, or know a good place to buy them? Tey are to mount a front LED lightbar low using the oem roll cage bolt locations. Please LMK
If you're trying to mount a light bar directly to the mount then yeah they suck. The light will never stay in adjustment. If your using the mounts that come with the light bar and mounting like I did there's no issue. This is the same set I've had over a year now on two different sxs.
I don't think the ones you posted below will work at the bottom of the cage mount. I don't see how you'd get them between the plastic/cage or even be able to tighten the bolts if you go it on there.
Probably won’t work for that particular application... but when you need that type of bracket... the way the TSC clamps is waaaay better. I used the kind you posted on my rear and side lights and they were just a b**** to use... once they are spread to go over the rops they distort and you can’t get the bolt through... not to mention they don’t allow for a good means of tightening the clamp.
The best way to mount that front light bar is with the brackets matt/ @redbank34 makes.
