Anything else I can do for heat?
Isaiah
Isaiah
2,191
6,964
Altamont TN
Is there anything thing I can do for rear seat heat? It isn't that bad but it is uncomfortable
And thanks in advance
Reactions: Russ989
Russ989
Russ989
22,642
147,257
The rear seat would be tricky, maybe some heat shielding of some sort. @ToddACimer
Reactions: Isaiah
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
On both of my 1000s I've added hear shielding under the feet of the rear seats.
IMG 20200301 131446
Reactions: Russ989 and Isaiah
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
Did it help much?
Yes. Surface temp is better for sure. We don't spend much time sitting still so overall it's a bit cooler. I have an underseat fan that I've been running for the last year and I just added a ceramic coated header today
Reactions: Isaiah
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
Here's a picture of the header and a link to my build
IMG 20200301 095438
Reactions: TimG and Isaiah
Isaiah
Isaiah
2,191
6,964
Altamont TN
Yeah I ride slow and technical terrain so it gets pretty warm. How much did the fan help?
Reactions: TimG
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
The fan helps a lot. I have a radiator fan override switch too. If we are in 4x4 or low range I flip both fans on high
Isaiah
Isaiah
2,191
6,964
Altamont TN
I am in low range a pretty good bit. I think I will be putting on a fan and heat shield:)
Reactions: TimG
Mudder
Mudder
NTC Ambassador of Walls
11,692
88,500
Rubber works good as well to block air flow into passenger area, and does not hold moisture, like the P500 trigger shield.
@trigger .
Reactions: Isaiah and trigger
