Automatic Reverse Lights And Override Switch
208,728
Hello. Just to make sure I understand correctly. I would need this product and this product (or some sort of light setup) to make this all work properly. Plus a switch plate and what not already installed in the sxs.
Yes if you want your lights to work while not in reverse. I just set the parking brake and put it in reverse?
67,176
Almost.
You will need a way to supply power to the rocker switch.
If you don't have a fuse box you can wire it to a key-on circuit.
And...
If you don't have that, then you need this.
N
nick1329
Columbia
Almost.
And...
Cool. Thanks. I plan to follow this guys tutorial,
, to install a fuse box and relay and then I'll install a switch panel and such.
