Anyone run one of these? Seems cleaner then having to run all the wires to a big switch panel in the cab. Just curious.
Yep, like @Hondasxs said it works great for lights, radio, things like that you only need a simple on/off switch for. Be cool if there was a setting for the Auxbeam to power on whatever accessory automatically when it got power, but from what I can tell you have to press the button every time... I'm also an electrical retard so there's that. I REALLY like just plugging in a couple wires to the switch panel and it's good to go.@Adam490 is running one in his talon. I ordered one, getting ready to install it shortly.
Ditto! I've got a new winch coming from the store that I'm hopefully not going to install!Yep, like @Hondasxs said it works great for lights, radio, things like that you only need a simple on/off switch for. Be cool if there was a setting for the Auxbeam to power on whatever accessory automatically when it got power, but from what I can tell you have to press the button every time... I'm also an electrical retard so there's that. I REALLY like just plugging in a couple wires to the switch panel and it's good to go.
I like it. I went with the upgraded version so I can control colors (to match my sxs) Momentary, and flashing switch options as well.How are you guys liking the auxbeam so far.
Right. Thats why its designed for like a key on trigger for example.I installed one I like the panel but if you hook it up to acc it shuts off with the key if you hook it up to constant power you can't turn the lights off on the panel so it runs the battery dead unless someone knows something I don't.
The blown fuse never crossed my mind. thank you, ill take a look at it when i get home from work.In reference to the blue plug.
- White wire with black stripe is key-on.
- Green wire is ground.
If you touched them already you have blown the fuse. Fuse box between the seats
Also, check whatever you are plugging into the blue connector to see if pins are bent.
Then run both white and green to the small post on your stinger.
Should be a 10 amp ACC fuse.The blown fuse never crossed my mind. thank you, ill take a look at it when i get home from work.
I get it, but I like to listen to the stereo when the bikes off or let my whips glow at times .. kinda defeat the purpose of the control box if you are adding rocker switches . Not a great designRight. Thats why its designed for like a key on trigger for example.
That might be your problem though, you’re trying to install it on a bike 🤣 If you put it on a side-by-side you can where are your stereo to a separate switch relay and fuse. That’s the way my stereos wired up. But in the end if you don’t like the switch panel don’t buy it. Buy a fuse and relay box and get you some switches and make your own Panel then you can wear it anywhere you like.I get it, but I like to listen to the stereo when the bikes off or let my whips glow at times .. kinda defeat the purpose of the control box if you are adding rocker switches . Not a great design
