P1000 Auxiliary Battery Info Needed
SBarben
SBarben
7
16
I picked up a new auxiliary battery for the Pioneer and installed it. Connected the LED light bar to it as well as the winch power and the CB.
My question is, after I got done doing all that, I looked for a wire that would allow the battery to charge When the unit is operating and didn’t see one. If there is supposed to be a charging wire connected to the positive side, where would it come from?
Hillbillytnt
Hillbillytnt
552
2,030
Ky
I think Honda just supplies the spot for the battery.
Russ989
Russ989
22,642
147,257
Take a picture so I can see what you’ve done. You will need an isolator and a couple cables.
Reactions: Ridinfool
Russ989
Russ989
22,642
147,257
Here’s a few pics so you can visualize.
F78A01D9 B080 4C50 A9FA D293A7C4DC11
A7E1E95B 8919 45CD BDA6 D24A751180C4
sharp
sharp
3,757
14,955
Tennessee
Like @Russ989 said you will need a battery isolator. You can get one in the Honda sxs store on this site.
Haldog77
Haldog77
NTC's Mafia Enforcer
40,033
347,346
Bossier City, Louisiana
I know that after the isolator is installed, a fuse block will help keep things in order and not all attached to the secondary batt. In my case I first used a six fuse block and then I later had to change to a 12 fuse block. You will be adding more and more electrical items. Good luck.
SBarben
SBarben
7
16
Wow!! Thank you so much for this!! This is exactly what I needed in order to finish. Super helpful!! Thanks again guys! I have a fuse bloxk i'm going to install along with the isolator.
Ridinfool
Ridinfool
36,144
386,046
Western North Carolina
What @Russ989 said, I also got the key on plug and play to trigger my isolator and my stinger and my wEnch. It was easy to install and I ran it to a buss bar so I could use it for other key on items.
Reactions: Mudwing and Russ989
Russ989
Russ989
22,642
147,257
Which MM battery did you use? I'm just getting started in the SXS world! TIA
I’m trying to find which one I bought. Stand By..........
