Auxiliary fuse block for the Talon
stellarpod
stellarpod
821
3,024
OKC, OK - USA
For those of you who have mounted an auxiliary fuse block on the Talon, where did you mount it? I've purchased a block, and frankly, I'd prefer it up front somewhere, as most circuits are going to require an accommodating switch anyway. I'd want it behind the splash curtain, but as easily accessible as possible.
Alternatively, I could mount it back near the regulator or battery, but that would just mean routing wiring from back to front. Perhaps the best solution is one in both places. 😁
Your thoughts?
Steve
Reactions: CID
DRZRon1
DRZRon1
863
2,784
IMG 4300
IMG 4302
IMG 4309
Reactions: stellarpod and CID
DRZRon1
DRZRon1
863
2,784
I mounted the fuse\relay box above the radiator but clear of the hood. I wanted to maintain airflow thru the radiator.
DRZRon1
DRZRon1
863
2,784
very very nice install, I didn't do a 2nd battery, but went a different route with that pre-wired jeep console\relay box - couldn't pass up for $130 plus didn't have to do all the switch wiring.....pita, lol.
IMG 6112
BPINE
BPINE
73
90
San Jose, Ca
www.youtube.com
If I were to do it over again I would use a switch pro, it isn't cheap but no need for fuses and make wiring a breeze. I just put one in my Jeep and will someday rip all the fuses and switch's out of my Talon and put one in that.
