G
I'm installing a Badlands Apex 5500lb winch in my 2024 1000-3. My question is about the wiring.
The Badlands instructions show yellow and blue cables from the winch to the solenoid - no problem. Hot/red from the solenoid then goes to a quick disconnect/shutoff switch they provide, then hot/red continues from the quick disconnect/shutoff switch to the Pos. terminal on the battery. Black cable obviously goes from the negative terminal on the solenoid to the negative terminal on the battery.
I've already ordered the single-wire pigtail so I can easily pick up key-on power and will wire the hot lead from the cabled remote harness to that, the two lugs from the cabled remote harness to the solenoid, ground to the solenoid, and the supplied connector to the supplied dash rocker switch, so that covers my handheld cabled remote.
My question is this:
Do I need anything else to protect the system and where would it get wired in? I'm not clear, following the Badlands instructions, where this setup is fused, or if it's fused at all. What protects the winch in the event of an overload?
Thanks very much!
Thanks very much!
