With the 100's of youtube videos and online writeups I still get questions about how to wire up a dual battery kit for the Honda Talon.
So I figured I'd draw up the basic diagram. You really can't get any simpler than this.
Please keep in mind this is the dual battery only and does not cover adding accessories which you should do after you complete this step.
We now also have a dual battery kit specifically made for the Talon along with battery trays in the club store.
To install your dual battery kit you need:
INSTRUCTIONS.
Once completed, you can begin adding accessories such as a fuse box, stinger, and winch to the second battery.
- Dual Battery Kit --> fix proper** link Honda SxS Club Online Store
- Battery --> fix proper** link Honda SxS Club Online Store
- Battery tray --> fix proper** link Honda SxS Club Online Store
INSTRUCTIONS.
- Locate the large gauge Red and Black wires with blue tape under the driver's dash around the settering column.
- Hook the factory large gauge positive to the main side of the isolator.
- Use the provided red large gauge wire with the Talon Kit, connect the isolator to the second battery.
- Hook the factory large gauge ground to the second battery.
- Hook the small black wire to ANY GROUND, frame, or battery.
- In the factory battery box, locate red wire with blue tape hidden behind it, Hook it to the primary battery.
