P700 Battery isolator
Sheepdog
Sheepdog
67
70
Lyles Tennessee
Before I order the parts to run my aux battery set-up I was wondering what the difference is between the True battery isolator and the stinger isolator/relay. Do they both act as battery isolator. I see both used in the same set-up for running a aux battery but not sure why you need both if they do the same thing.
Stinger can be made to connect the batteries for a self jump. The true iso can’t
Reactions: Sheepdog
Sheepdog
Sheepdog
67
70
Lyles Tennessee
Ok so in the videos I’ve watched I see both used for the same system. Does the stinger act the same as the true isolator as far as the main battery safely charging the aux battery. I guess I’m wondering if I need both to safely operate a dual battery setup. Thanks
No the true is fine by itself but you need a 6” piece of jumper cable to self jump if your main battery dies for some reason. You can’t force the true iso to connect them it’s solely by system voltage.
Sheepdog
Sheepdog
67
70
Lyles Tennessee
Ok, so if I use both and the main battery dies, I can use the stinger to start my p700
swsebek
swsebek
2,854
5,835
pa
Yes the stinger will switch over to auxiliary battery and you can start If factory one dies. On the True utv isolator you have to keep a 6" piece of wire handy and if main starting battery dies you have to jump terminals with it manually. Which is no big deal. I use the True and am very happy with it. Once you get one it's easier to see what your working with.
70Bones
70Bones
888
3,779
New Brunswick Canada
Can't figure out how to start a new thread, so I'll resurrect this one... I have a question about battery isolators. Will the isolator allow both batteries to be charging at the same time?
swsebek
swsebek
2,854
5,835
pa
Not at the same time. The isolator cycles back and forth between both battery's or stays on one if its lower then the other.
70Bones
70Bones
888
3,779
Does it charge the battery with the lowest voltage? Hypothetical... if the aux battery is dead from running the stereo all night, and you start the machine the next morning, will the isolator allow the dead battery to charge and let the main battery voltage drop until, maybe, there's not enough power in the main battery to run the machine?
swsebek
swsebek
2,854
5,835
pa
Im not sure, now you have me wondering too
swsebek
swsebek
2,854
5,835
pa
Hypothetical--- yes it charges the one with the lowest charge first. And I'm assuming it would charge the dead auxiliary battery until it reaches the others charge. But I have never monitored it for a definite answer.
Reactions: 70Bones
70Bones
70Bones
888
3,779
I guess a DC Clamp on ammeter would be the easiest way to check. Here I sit, with too much time on my hands and brain churning away...
Reactions: swsebek
67,170
If we are talking about the TrueAM.
For this example. Say both batteries are low.
Then.
It charges the master battery first. Once it gets to above (x) volts it will turn the isolator ON and charge the second battery.
If the first battery never reaches (x) volts. Then it will never charge the second.
That's how I understand it to work.
70Bones
70Bones
888
3,779
Then.
Ok, so in my hypothetical situation, it would charge the #2 battery until the main battery gets down to a certain voltage, then switch and top up the main, then go back to the #2 battery. Makes sense now, thanks guys!
