P1000 Battery mount fuse block
Cooterbob
41
37
Ohio
2291E7D2 B878 4FE3 AC79 A40D4AEE8E73 Anyone try this? I plan adding backup lights, small light bar, a dome light, and 4500lb viper max winch(already installed). Also have ssv works sound bar with 1000watt amp and 2 sjs design speaker pods. I have 2nd battery on way with true isolator . Will this work ? Limited knowledge on wiring here.....
CPope
CPope
352
1,152
Pulaski TN
If you are doing same style battery as factory, I don’t believe it will work. If you are using an automotive style under the seat, it will. Looks like it mounts by top post.
Reactions: JTW
Cooterbob
41
37
Ohio
That’s what I was thing also. Thanks
