battery relocation
1trkyhntr
9
I have been searching everywhere to see if anyone has upgraded and relocated there battery to under the hood. if so I would like to see pics. if this is even possible. just have been wondering about this.
Sxsnewbie
Sxsnewbie
298
103
Eastern Connecticut
Someone had just posted in another thread that they used an ammo can and put it under the hood. But it was in a P5 and there were no pictures
Several people have relocated the battery to under the hood. Using a varied assortment of materials as a battery holder. You can do a single battery setup using a larger capacity battery (2015 Goldwing is a close fit and larger capacity 18ahr, over stock pioneer battery 12ahr)or you can install a dual battery setup, where you pick two batteries, which are generally recommended to be the same for longevity reasons. That has an automatic isolator a manual switch.
There is also the option of installing it/them under the drivers seat. Which frees up the space under the hood for storage/heater/power steering/3rd battery. You can stuff up to a 75ahr battery under there. I have an 55ahr Optima under mine because I killed the factory battery winching.
::Edited for specifics and spelling::
1trkyhntr
9
thank for the replys. im wanting to put some accessories on and figured a bigger battery would help.
big31moe
6
I added a gold wing battery under the drivers seat and kept the original equip battery is stock location. This makes the use of the winch much easier and cold starts are much quicker.
W
Westtnpioneer
Edjumacated
350
603
West Tennessee
I used the Red Mountain kit. It worked well although i had to do a little trimming, but having a larger battery was a must.
1trkyhntr
9
would like to see some picture please.
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
Check out red mountains page (link on ohanacreeks post) there are pictures of the battery relocation. Looks like what you need
Thanks TFlynn, turkey hunter if you have any questions just PM me
motorcikle
motorcikle
9
I used the Red Mountain kit, piece of cake to install, now I have a full size Optima Yellow top under the seat.
Reactions: ohanacreek
