P1000 Battery terminal extender
Wisco_rider
Wisco_rider
31
79
Hartland,wi
What is everyone using to extend the battery terminal on the 2nd battery? I have seen the odyssey l brackets, but those seem way over priced for what they are. I just want something I can attach to the 2nd battery permanently that will move the terminal up and make it easier to connect/disconnect terminals.
Any suggestions? Preferably something I can pickup at a local hardware store so I can get all my electrical figured out this weekend.
Neohio
Neohio
Beast of the East
17,743
85,592
Painesville Ohio
Wander thru your local hardware store. Find a 90 bracket. Open up the hole to fit your bolt. Done.
Reactions: TxDoc and TripleB
G
gearguywb
27
56
Kansas City
I tried to find one yesterday with no luck. It is doable, but a PITA to use the terminals on my second battery as is.
Neohio
Neohio
Beast of the East
17,743
85,592
Painesville Ohio
All sorts of brackets available on Amazon. just look for right angle brackets.
Reactions: Mudwing
Wisco_rider
Wisco_rider
31
79
Hartland,wi
Something like that, but straight, I could always bend it flat. Does it matter what type of material do you think?
Neohio
Neohio
Beast of the East
17,743
85,592
Painesville Ohio
Tabletop connectors?
1589461798736
If you want copper, grab a few plumbing unions and smash them flat. drill 2 holes and you are done.
You could also run a short battery cable to a bus bar or junction block and attach everything else to the bar/block.
Reactions: Mudwing
Formula1
Formula1
160
264
SE Missouri
I think what I am going to do is just get a longer terminal bolt and separate out each connector with a nut. This should keep them all tight. I am planning on finishing up the wiring this weekend now that I have gotten past the panic phase of what to do with all the wires!!
BBLASER
159
277
Phoenix
For 6 bucks why go thru the trouble of trying to rig a longer bolt with jam nuts on it?
Reactions: TripleB
Formula1
Formula1
160
264
SE Missouri
Even with that you will be stacking rings on top of each other. I just figure with a longer bolt that each eyelet will be tightened between nuts. 6 in one half dozen in another I guess.
Wisco_rider
Wisco_rider
31
79
Hartland,wi
Its another $5 to ship and will take a week.
I have no intention of using jam nuts. I just want something to extend the terminal so I can get at it easier. Trying to replace the screw and nut on that tiny terminal is the pain in the rear
