P1000 Battery Upgrade Time
Jdiehl7
83
103
Houston
92b3db58dcd8b451cae4f7f6cf433d05 Running a dual battery set-up with an odyssey right now and it just doesn’t have enough power to keep up and last all night hog hunting while using lights, fan, radio, etc. Installed a noco marine single bank battery charger and an optima blue top deep cycle. Mounted a battery tray with hold downs to keep it secure! Running cables tomorrow to fuse panel and isolator!
Reactions: TripleB and BWAF
BWAF
BWAF
I get paid to pass gas
8,860
42,462
Carthage MO
View attachment 157551 Running a dual battery set-up with an odyssey right now and it just doesn’t have enough power to keep up and last all night hog hunting while using lights, fan, radio, etc. Installed a noco marine single bank battery charger and an optima blue top deep cycle. Mounted a battery tray with hold downs to keep it secure! Running cables tomorrow to fuse panel and isolator!
That should do it
Jdiehl7
83
103
Houston
That should do it
Mounting the charging port between the seat bottom and seat back for easy access with the extension cord!
Reactions: BWAF
BWAF
BWAF
8,860
42,462
Carthage MO
Could mount it in plastic in between legs I put fan switch there for bilge fan for seat heat 665e08d892149d4756c4d236b444732e6e0781bdc4593b6305d3bc66aa69d69f
BWAF
BWAF
8,860
42,462
Carthage MO
All my switches are on the dash. Want to put it between the seats so I don’t have to reach down into it or open the door to plug it in.
I hear you
DDDonkey
I have my NOCO charging port on the dash, they make one that goes into an empty switch blank. That way no extra holes need to be cut.
P1K5Dave
P1K5Dave
2,225
8,349
Petoskey, MI
Hey @Jdiehl7 just dug up you old thread to see how this setup worked out for you. I'm considering going with a deep cycle under the seat for a lot more lighting power.
I had read here that the stator on a Pioneer might be hard on a deep cycle battery (?)
Also wondering why you went with the charging port, do you find that the stator isn't enough to keep the deep cycle up? You plug it in overnight when you get home?
Also looking at whether to bring both battery cables up under the hood, or just grounding the black at the chassis.
bumperm
bumperm
1,889
6,743
Gardnerville, NV
As long as the two dissimilar batteries (in brand, size, age, etc.) are not directly connected in parallel (use an isolator such as the True), then the on board charging system should not be an issue. Be aware that under seat temperatures may have a negative impact on battery life.
An external charging plug is convenient. Mines on the front grill, using Powerlet plugs:
20210717 165206
113,735
Similar to my set up
16EB5BCE 50BD 44AF A400 0454EC26CC51
ECE7187B DCEE 4FBA 806C B25198C359E7
Hardwaterflyer
65
102
West Central Minnesota
When charging two dissimilar batteries, primary is Yuasa {since new] secondary is charged through the "True" isolator does the secondary battery [Odessey PC 925 X-treme] ever get fully charged using just one BatteryTender charger hooked up to the primary Yuasa battery which is the starting battery? The Yuasa battery is strong but the Odessey is not doing its job cycling the snowplow up and down anymore. Time to replace the Odessey or go with a separate AGM trickle charger? Both batteries are from 2018 same year as P-1000-5 Camo. Purchased new.
Neohio
Neohio
Beast of the East
14,465
72,304
Painesville Ohio
Disconnect the true isolator, apply charger to Odessey by itself.
Let it charge over night before getting battery load tested.
Inspect your positive and negative cables from battery to iso to battery etc.
I have been burnt in the past using CCA (copper coated aluminum) battery cables. These last about a season before they rot away and lose connection.
If buying cable on Amazon or online. Make sure it states OFC (oxygen free copper) in the listing and on the cable. These will last so much longer on your machine.
bumperm
bumperm
1,889
6,743
Gardnerville, NV
In their installation instructions, True suggests connecting an external charger to the Aux battery. Once the Aux battery reaches approx. 13.3 volts, the True will start charging the main battery also. It'll work with the external charger hooked to either battery, but their logic is the Aux battery is typically going to be the one that's more deeply discharged.
