GROR
The art of clean wiring
Application
2022-2024 HONDA PIONEER 1000 - 1000-5 - 1000-6
The Ghost Rocks Off-Road Dual Battery mounting system optimizes the premium space beneath the Honda Pioneer 1000 hood by letting you customize and design your electrical setup based on whatever components fit your needs. The two-part mounting system includes an Aux battery fuse box mount compatible with Auxbeam models AR-800, BA80, and GA80 fuse boxes and an interior mounting plate that replaces the warning label on the 2022-2024 P1K dash. With the Aux Beam, wiring is straightforward, ensuring simplicity and organization while adding eight additional relay-protected circuits for accessories. When an AuxBeam kit is not used, the battery mount can mount several elements in a typical dual battery setup, e.g., a speaker amplifier, stinger relay, or an auxiliary fuse box.
The second part of the GR-2 mounting system includes a custom-designed front airbox auxiliary mounting plate, a 3 " ID 4-ply reinforced silicone 90° elbow with clamp (which uses the stock air prefilter), and a Universal 4-slot relay bracket.
All Ghost Rocks Off-Road custom products are built in the United States by skilled workers at a fair living wage. GR-2 Components are laser-cut from high-carbon USA Steel and powder-coated for corrosion resistance.
Application
