P1000m5 Dual Battery Diagram...Sorry in advance.
Hillbillytnt
Hillbillytnt
559
2,053
Ky
Al
Still being dense I guess. Red and black, got it. Either green to back of dual meter. Got it. But how does the other green “make the isolater go on and off?” Where would that green go?
To the small ground on isolator. This will cut the ground when not powered and make the isolator kick out blue light off. Again this isn’t necessary the light will go off on its own but if it’s bothering you this will make it key on only.
P
PioneeringMO
26
59
Got it! Thanks to you and the others that coached me along. I really do appreciate it. I’ve never messed with relays so the idea of a keyed hot wire triggering a ground was pretty foreign. I somewhat get it now. Again, thank you all.
TripleB
TripleB
20,628
180,388
Caryville, Tennessee
I’ll keep those in mind if I try to change mine. For me it’s not that big a problem I’m in south eastern ky so it does it maybe twice a year if that and it never lasts that long. Just a couple minutes at the most before it thaws. Late season black powder has some frosty mornings and early spring turkey has a few but it usually kicks in before I get out of the driveway. For someone plowing snow it could be a big problem.
You can say that again and again lol
Coltongreen
Arizona
@PioneeringMO
If you need any help/info I just installed my mine and can help you out. I can send the complete wiring diagram, etc.
My system has a light bar, reverse lights, soundbar and winch on the second battery. I put all accessories on an isolated switch as well.
Let me know!
Installing dual battery setup on 2023 trail. Could you send the wiring diagram of your set up? Thanks in advance
