P700 Bed side rails
mnmgri4
mnmgri4
12
16
Green Bay
Would like to add rails to the top of the sides of the box on a 700-2. Has anyone done this? I have seen some aftermarket rails for other brands of machines but not sure if bolting them on to the tops of the sides will work. Are the sides just plastic or is there material inside to re-enforce them and bolt too?
Thanks in advance!
Reactions: Alan_Vander
mnmgri4
mnmgri4
12
16
Green Bay
Thanks, I was thinking of drilling holes through the top of the side panel and anchoring the rails with a bolt and spring loaded anchor nut. Not looking to use them for tie down purposes necessarily but thinking of putting Kolpin Rhino grips on them for holding bows and rifles for hunting.
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
are you talking about those set ups that go rail to rail that you can accessorize?.
mnmgri4
mnmgri4
12
16
Green Bay
No, an individual rail for each side, may have to fabricate something.
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
not sure how good that would work with a gun sitting 6 inches up from the rail. for side to side motion that is. plastic is pretty sturdy but most other bikes like ranger have metal frame under the top for mounting stuff. depending in how the koplins mount might work better just using those straight to the bed
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
now if you mounted the rails then made a clamp rail that went to both sides that would sturdy it up a good bit
jwfirebird
jwfirebird
927
1,446
western ny
must be super thick, thousand lb limit and a lot of people use it for wood, wet maple I hauled like a dozen loads of big stumps, hard its just plastic.
it never deflected with like ten times the weight of a gun I think if you spread the load like he said it will be fine
mnmgri4
mnmgri4
12
16
Green Bay
The floor of the bed has a 1000lb limit but we are talking about putting the weight of the gun or bow on the top of the sides of the bed.
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
too bad the 700s dont have the panels like the 1000s do or you could put flat metal underneath the plastic to stabilize it more
jwfirebird
jwfirebird
927
1,446
western ny
when I do wood the stumps are probably 75lb each and I fill it over the top, going through mile of ruts and ditch they are not tied down, banging around in there the hole way up. it seemed fine, don't take it easy on my machines.
L2R
L2R
Understanding women Vol. 1
1,063
6,599
East of the Appalachians
Might consider rails hanging from the top rather than bolting from the plastic on the bottom.
I think you could find some quick clamps and fab from there and that would give you options later if you wanted to remove them at times.
