P1000 Best Synthetic Winch Rope Replacement for OEM 1000-5 Limited Edition
ChairMtn
Denver
I am prepping for an upcoming moose hunt in Colorado and would like to replace my steel cable on my stock with that came with my 2016 1000-5 LE, the only problem is I can't seem to find the actual spec on the installed winch and the machine is 4 hours away at my cabin. Does anyone know the model that comes on the LE and bonus points for best synthetic rope replacement? Going for length here, but don't want to go too light in case I need some more breaking strength. Advice is appreciated. Thank you.
JenElio
JenElio
70,775
649,269
Loxahatchee, florida
First post in 6 years........👏👏👏
🤔...I don't think the LE was available in 16' though.........but maybe🤷‍♂️
Dirtstiffs-1000
Dirtstiffs-1000
1,639
5,971
hondasxs.com
Amsteel Blue synthetic rope
3/8" 17,600 pounds break - 8-12k pound winch pull.
Link to Amsteel synthetic rope
Correction / Edit 5/16" Viper Elite widespool. 6000#
12,300 # break, 6-8k# winch.
65' on the spool.
5/16" Amsteel blue
A month ago I grenaded my 6000# Viper on a pull I shouldnt had .. also got what I paid for with the $20 buck Azon extendable rope - garbage, its just rope.
Share a Pic of the moose and your rig.
Good luck, good moose call grunt tube..
JenElio
JenElio
70,775
649,269
Also, if you swap from cable to rope you're going to want a fixed fairlead not the roller you most likely have on for the cable. You'd also be wise to check the drum on the wench because the steel cable can eat away at it sometimes and in turn it will chew up the new rope as well. Just some things to think about 👍
5,286
23,971
Dat's sum cerious overkill fer a 2k lb. SxS, Dude. And you'll get half as much line on your winch. I carry 100' of the 3/8" Amsteel as a winch extension though.
1662251599277 png
TripleB
TripleB
14,118
123,566
Caryville, Tennessee
I replaced my steel cable with cheap Amazon 1/4 inch synthetic rope. You can't beat 20 bucks. I winch stuff all the time with no issues. I replace it once a year, maybe 2 years. I always carry a extra with me just in case I break one. Which almost never happens. You will also wanna get a Hawse fairlead to replace your roller one. Another $10-20 from Amazon.
DRZRon1
DRZRon1
1,136
3,654
PA
And a good anchor strap for the opposite end - couldn’t imagine dead pulling a 1200# or so moose unless it’s kinda alive and helping you out.
5,286
23,971
If that moose is kinda alive and helping me out, I be prayin' that my buggy is faster than that injured, and now really, really angry, moose. :oops:
Hello_Darkness
Hello_Darkness
238
989
Just to the right of nowhere
The LE never came with a winch and wasn't offered until 2018.
Maybe you have a later model SE? Or perhaps the winch was dealer installed
P1K5Dave
P1K5Dave
2,220
8,332
Petoskey, MI
Same here. I went with a $20 ones and figured I'd carry a spare and see how they hold up before dropping 4x on the Amsteel.
I've beat the snot out of the first one for 3 seasons now just waiting for it to give in, and it hasn't.
Scrappapotamus
The Scrappapotamus
648
3,467
Midway KY
  3. Talon X
  4. Talon R
  5. Talon R LV
You guys need a fast Fid kit which allows you to stitch a broken rope back together. You might lose a foot or 2 of length but a much quicker repair, especially in the filth. I have one of these kits in all of my SxSs
bumperm
bumperm
1,887
6,738
Gardnerville, NV
RED ALERT DANGER
Some iffy advice in some posts.
Okay, firstly knotting a rope weakens it by about 50%. You do not want to tie knots in your winch rope. Learn how to splice the rope to fix a break, almost no loss of strength that way (carry a fid - they are cheap). Carry extra winch rope, (that's cheap too).
Consider that a winch weight rating is with ONE layer of rope on the winch spool. Two or more layers and the pulling power drops as the effective drum size increases - - kinda like shifting to a higher gear.
My 21 P1000 came with a Warn 4,500 winch with 50 feet of 1/4 inch diameter Dyneema. You do not want to use 3/8" rope on this winch for two reasons. You can't get the full 50 feet on there, not enough room, and you will have less length in the first layers of drum windings so your effective pulling power will be decreased. 3/8" is for the big boys with 12K winches - not us.
Carry enough extra synthetic rope so you can use a snatch block like this: Snatch block this synthetic line shackle and aluminum ring "block" will do just fine and DOUBLE your winch pulling power - - you just need enough rope to go out and back - - or in some cases to allow a more in-line pull.
ChairMtn
Denver
It’s a 2017 1000-5 LE. Just looked back at my receipt. Bought it 2018. Found a grainy photo on my phone and the hook shows Warn winch, perhaps it was dealer installed?
Lots of lurking here over the years. A couple of pics of my 1000-5 for reference. It 95% used for an off grid cabin we have at 10k feet in Colorado. It’s a five mile run in from the hwy in with winter on tracks. Great tool for the job. It’ll be nice to get it further afield for the moose hunt on Grand Mesa. Lots of 50” trails to look for moose on.
I appreciate all the advice and wisdom. I’ll report back, hopefully with some moose pics included.
IMG 4320 IMG 3565
DRZRon1
DRZRon1
1,136
3,654
PA
View attachment 443087 View attachment 443088
Good luck - shoot straight
