P1000 Blink Code 1-3
aauman88
aauman88
1,091
2,846
Took ours out for first major test today with family and after some fairly deep water it started shutting down randomly. Light would blink one long time and three short times. Turn it off and it fires right back up and runs fine until who knows when and it shuts off again. If I understand it correctly that’s 13 and is for the injector harness that’s a known issue, is that correct? If so I just need to buy the repair plug to get me by until I want the Honda shop to have my Pioneer for an extended amount of time??
I pulled a Pioneer from pretty deep hole today so good deed done, lol
6A135DD3 7BD4 495F B1B7 44A160C03696
aauman88
aauman88
1,091
2,846
Snorkeled and all vent lines ran to roof height. Thanks for the info. Hopefully I can get it in and fixed before the big ride on the 16th
65,023
Oh ya.
Can ship Monday.
I recomend soldering the connection and using the included adhesive lined shrink tubes to seal it off for good.
aauman88
aauman88
1,091
2,846
Thanks, ordering now soon as I look and make sure the wiring pigtails are all I need.
Reactions: Firemedic530
aauman88
aauman88
1,091
2,846
Order 2 repair plugs. Do them both. The small investment is still better than having to tow it to a dealer, or ruining a day of riding due to it not running.
Well crap, I had only seen an issue with the rear one or I would have definitely ordered another.
How hard are these plugs to get to?
Neohio
Neohio
Beast of the East
13,616
68,070
Painesville Ohio
If @Hondasxs hasn't shipped yet, send him a message to add another.
Very easy to get to. Remove the 5 10mm head bolts holding the seat back in place, then remove the plastic shroud/covering between the box and b pillar. Everything can be reached from there.
Neohio
Neohio
Beast of the East
13,616
68,070
Painesville Ohio
@Hondasxs Posted he will ship Monday. Definitely consider repairing both while in there.
aauman88
aauman88
1,091
2,846
Pulled it apart to change injector harness and when I was pulling the tape off rear plug the wire popped out of the plug. Rear is done and front one should be here tomorrow. Went to install K&N air filter and had to remove the entire assembly because three of the screws were stripped out. Cut slots in screws for now and will change assembly next time I tear it down.
Thanks to HondaSxS for the great parts and fast shipping.
CEB01071 3B70 46FC A103 293ECCB1D0B5 434040F5 5A48 4EA6 897E BD6B8565049B C4EF9156 03B8 4AFD 87A7 86DCA9677226
Neohio
Neohio
Beast of the East
13,616
68,070
Painesville Ohio
View attachment 112791 View attachment 112792 View attachment 112793
Your plug failure looks identical to mine.
Do you have pics of the finished install of the plug?
aauman88
aauman88
1,091
2,846
No but my front plug should be here today and if I get it changed tonight I will get some pics
Reactions: Neohio
0860silverado
947
1,817
louisiana
Reactions: Neohio
Neohio
Neohio
Beast of the East
13,616
68,070
Painesville Ohio
Hey thanks for the link! I just ordered two kits. One to properly repair my temporary fix on cylinder 1, and the other to replace my factory Honda plug which is destined to fail on cylinder 2.
Richard is out of town for a few days. It may not ship until Sunday/Monday.
Reactions: 0860silverado
aauman88
aauman88
1,091
2,846
Sorry for crappy pic. Didn’t realize it was bad until too far back together. Not the prettiest trying to splice and keep it neat but it’s protected and has good connections now for sure.
Got my mount done for bilge fans too. Now to wire them.
87C4E2BE B4F2 4D5A B5B8 8D22966530C8 44BA1A15 E56D 49E7 BCF6 CD684B4AC95A 48CA1872 C167 4300 891A F92D6551E23A
