Once and awhile the brake pedal doesn’t have pressure when depressed, I let up and next time it’s perfectly fine ? Air in line ? Any good ideas full of fluid so it’s not low !
Do you have A-arm guards on the front?
Seen some that hit the caliper at full suspension extension.
doesn't happen all the time but it pushes the piston in so the next time you use the brakes the pedal goes to the floor pushing the piston back out.
