I was needing a place to mount the DC Buss bars I got off Amazon. I have not yet been able to bring myself to drill holes to mount them, so while in Home Depot I found the same Velcro type that the dual battery Isolator comes with.
I will be running all my rock lights and LED's from these buss bars. A relay tied to the high beams will provide the power to the busses. As things progress and grow, I can change these around.
Basically it is blocks to wire in the 12volt hot and grounds. Mounted with industrial strength Velcro. The ground buss is mounted on the auxillary battery housing to use that real estate.
I was needing a place to mount the DC Buss bars I got off Amazon. I have not yet been able to bring myself to drill holes to mount them, so while in Home Depot I found the same Velcro type that the dual battery Isolator comes with. View attachment 95049View attachment 95050
