P1000 Can you put shorter tires on P1000eps?
E
Ericthered
Eric The Red
271
522
Sparks, NV
I have a height issue on my 2017 Pioneer 1000eps-3. Can I safely install 25 inch tires on my steel 27x12x9/12 rims? Anybody have experience doing this for same reason? Any help will be appreciated. I can't buy a new toy hauler.
ToddACimer
ToddACimer
Pioneer 1005-2
3,578
14,707
Oshkosh, Wi
You can. You'll want to make sure the load rating on the smaller tires is sufficient for a UTV. 6-8 ply minimum. Your ride quality may suffer with the shorter sidewall. Obviously you will loose some ground clearance. Another thing to consider is the 27" big Horn tires on the deluxe models barely measure over 26" so a large, true to size or more aggressive 25" tire may not be much smaller
Reactions: Plumber32
E
Ericthered
Eric The Red
271
522
Sparks, NV
why not let some air out of yours while your trailering it?
Tomorrow I will try putting it in my toy hauler. We'll see what it takes. Measurements show I have 1/16 of an inch of clearance. I'm hoping that the front of the rig drops as it enters giving me even more room. Keep you advised.
allgm1
allgm1
1,049
1,484
New Hampshire
I have that problem getting in and out of my garage, I can drive it in because the roof will just rub and the angle of the dangle on the roof going in is fine but when it comes time to back out I have to grab the ROPS in back and pull the back end down a little and roll it out a bit to clear.
drfubar
drfubar
TheDonFather
5,889
19,233
Mary's Ridge (Dayton Mtn), TN
I had some small tires on my rig for when I ran to town.. They were ok just didn't like the way they lowered the top end with being on the highway and all.
67,760
Just grab some ratchet straps and tie down the suspension. Bumpers to a-arms. Get 2-3" easily this way.
E
elkguide
3,377
7,964
Vermont
If it is for toy hauler clearance issues, I'd chop the top rather than use smaller tires. The handling would be so different .
Reactions: joeymt33
jpman
jpman
23
34
Oklahoma
I have the same issue. Bought my toyhauler for my streetbike, later got the pioneer. I need 8 inches, so I'm trying to find a small wheel/tire combo just for loading and unloading.
W
wyodlr
147
209
Cody Wyoming
Evan a 12" wheel with no tire won't give you 8"
Reactions: elkguide
JPP44
5
Decatur, Al
What kind of toy hauler do you have? I am looking at a Keystone Raptor425TS for my P1000-5. Dealer says it will fit but I won't buy until I see it inside. Light bar on front of roof but I think slope makes light bar even with rear of roof. It goes in 7' high garage door with a couple inches to spare. I am more concerned about width of Honda and being able to open door and get out after driving it inside. I assume all toy haulers are same width except for garage seat or bed considerations.
jpman
jpman
23
34
Oklahoma
Maybe I forgot how to read a tape measure, my rear tires are 24 and a half inches tall, stock wheels are 13, that's 11 inches difference. I'm thinking tread for recap tires screwed to a set of stock steel wheels would work, might have to winch in, but could drive out, play pit crew with a small floor jack, impact gun and a beer should do it.
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,157
Cullman, AL
  2. Other Brand
11 divided by 2
