BOX1 - TEST
Carnivores in 32s
Choped5er
Choped5er
182
279
Union
Has anyone measured a 32-10-14 carnivore? Iv heard they run real small and if they do I'll go with 32s but if the 30 runs big enough I'll go with them, any help is appreciated
39,079
They do run small. But this size greatly depends on air pressure. Under the weight of the pioneer they could be 30 inches with lower air pressure but could be 32 if you wanted to inflate them to the max.
Here they are next to 32 inch Terrabites
Ef3e75a6cca7842061f00c3c14aa3e3e
They’re not like the roctanes which are big. This is the same Terrabites next to a 30” Roctane.
5b01c64e406fc44653d0ff50dab05736
The two on the left are inflated and the one on the right is not mounted on a wheel.
Choped5er
Choped5er
182
279
Union
That's awesome comparison there, I have 30" roctane X2 rn wich I assume run as big as the og roctane. So most likely I can clear the 32 carnivores. I have Satv arms and 814 shocks
Reactions: joeymt33
Choped5er
Choped5er
182
279
Union
I also normally run about 6-7psi, but the psi wouldn matter about the top of the tire as much would it? I'm just wonrried about clearance
39,079
I usually run them 9-11 depending on number of passengers.
It wouldn’t stretch the top much but it will some.
Reactions: Choped5er
Choped5er
Choped5er
182
279
Union
Ten4 hopefully i can clear them, I'm probably going to order them in the next few weeks once I get my rig back together
39,079
With 2 inch forward a arms I had some rubbing issues. But I’m not running hardly any lift at all. I did move my arms forward a little bit more and they clear.
BeerMonkey
BeerMonkey
455
1,515
Mid TN
here is a 32" rampage unmounted next to a 30" crawler with 10psi. the rampage is a little bit harder and will last longer than the carnivore, and is also supposed to be a bit tougher. im getting them mounted right now
20190321 183908
Choped5er
Choped5er
182
279
Union
Moved them forward by running the camber bold in on front and out on back?
Choped5er
Choped5er
182
279
Union
I like the rampage but I like the soft compound tires better, don't ride all that many miles normslly so not super worried about wear, rather have the most traction possible
Reactions: Ragnar406
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
How did you like the roctane X2?
39,079
The CATVOS front arms are already 2” forward and they have heim joints. I adjusted the heims to move it more forward. The heims are where the arms meet the frame.
BeerMonkey
BeerMonkey
455
1,515
Mid TN
If you want soft you need to get the rockzillas in sticky compound. they will climb up a slick wall. the lugs are soft enough you can squeeze them together by hand.
Choped5er
Choped5er
182
279
Union
I like them alot, they bite on anything, just to heavy for me. They are for sale with less than 200 miles if you want them
Choped5er
Choped5er
182
279
Union
Do you know how true those run to size? I love the size of my 30 roctanes, that's why I was wondering about 32 carnivores
Reactions: Isaiah
BOX2
box3 - TEST
