P1000 Chainsaw Mount
Bonehead69
Bonehead69
73
44
Anyone have some ideas for mounting your chainsaws?
Donnie
Donnie
102
146
SW Missouri
Intrigued...
I've seen ones where the bar goes in like a sheath, but I'd be afraid the Bar would bend. I gots me a big ole Husky. She's a GOOOOOOOODDDDDDD Dog...
ghost
ghost
993
1,873
BC
I was going to make one myself but I'm starting to like the looks of this Kolpin. Good reviews and lots of mounting options on the P1000.
Bd2MJwCWkKGrHqIOKioEwPgBihBMNkinn1g 35
Reactions: JACKAL
F
Fullthrottle
164
84
I have a kolpin works fine.Chainsaw is an important thing to take on rides.
ghost
ghost
993
1,873
BC
At first I thought something like this would be good. Just zip ties holding it but was going to build a rack.
IMG 2294
Then I tried some Kolpin Ratcheting Rhino Grips
IMG 2357 IMG 2355 IMG 2365 IMG 2366
What I didnt like is the kolpin grip is mostly plastic and I could see the chainsaw breaking loose when I hit a bump. So I used some 1/8" wire rope on the roll bar which holds all of the weight of the saaw - the Rhinos just keep the saw from swinging. To unload the chainsaw, there is a quick release hook on the wire rope and press the button on the Rhino - then pull the saw sideways and out the back. The scabbard swings a bit for the saw to come out but stays in place until you slide the saw back in place.
Been on some bumpy rides and this setup works well. Easy to load and unload. You can use both rear passenger seats while the saw is in place and the bed dumps all the way too.
Here is the upper Rhino Grip attached to the rollbar and the quick release - you can also see the turnbuckle to adjust tension on the wire. The wire needs to support the weight of the saw.
IMG 2378 IMG 2379
Update - I tossed the turnbuckle and simplified the wire rope / quick release. Really happy with this.
IMG 2842 IMG 2841
dale5740
dale5740
886
417
mt airy md
how do u have your farm triangle mounted
hurld
hurld
129
159
Here's a closer look at the modified koplin mount591c501ab2d728cd5b8817d63648543cA1eb93c6c7ade6b7cc8232d64fd6b667
hurld
hurld
129
159
Yeah the little 170 gets cleaned more than the pioneer, but is worth it's weight in gold when the trail is blocked ;)
dale5740
dale5740
886
417
mt airy md
thats the truth don't leave home without it. I am thinking of getting a small stihl to take with me and when Im going to cut wood then take the big one!!
66,869
I am going to have to out some thought into this... I really could of used a chainsaw holder today!
Manwell
Manwell
803
2,439
With some recent conversation about an adventure in Coalmont, TN with @drfubar and @Delton it brings the topic of a good chainsaw mount front and center! I've though about it as something I would do sometime in the future, but now I'm thinking that perhaps I should be considering it sooner rather than later!
Has anyone tried a mount that just rocks? I'm leery about mounting anything off to the side or even that protrudes at all from the ROPS on the side.
