Note about clutch adjust & oil level... My 2015 P-500 was running & shifting fine, then tried a Honda tech 1/3 turn suggestion, and it wouldn't shift out of 1-2-or 3 unless way off, or off of gas pedal. Went back to 1/4 turn still bad shifting, tried a little less than 1/4 and still bad, went back to 1/4 still bad. Was driving me crazy, until I checked my oil dipstick, and I use full synthetic, it was surprisingly 1/3 to 1/2 quart low. Filled it up to upper dipstick level, completely solved the shifting problem. Turns out that with low oil, my clutch adjust attempts were way out of whack. After filling it up to proper oil level, checked clutch adjust again, and it was nowhere near 1/4 turn that I had set it with lower oil level. So now with full oil, did adjust again to 1/4 turn and it is shifting perfect again. Don't know how or why, but low oil level will not allow proper clutch adjustment, at least not with my P-500, thought others should know this. I also learned, and after reading a comment by Trigger in 2016 that with full synthetic, (thinner & more slippery) some oil can get past the rings, ever so slowly. I've now learned to check my oil level more often. I've been around machines like this my whole life, never had one use any oil, always same level on dipstick every check using regular mineral oil. Seems full synthetic can reduce oil level over time. Both my Can Am machines call for full synthetic oil, and they do need some topping off now & then.
