P1000 Code 24 - Shift Control Motor
Bakesauce1
Klamath Falls, OR
I had a big storm come through while hunting and a couple days later it started just fine and died when I shifted into gear. Had to put it in E to get back to camp. Went through some connections and when I unhook the PCM the E code goes away and flashes “-“ very quickly. Does that mean it is the PCM? This is a 2016 1000
Reactions: Lady01 and TxDoc
66,818
PMC most likely controls the code. But not to rule it out.
24 is the shift motor code.
See attached.
  • code 24.pdf
Reactions: Lady01 and Mudwing
Bakesauce1
Klamath Falls, OR
Thank you. This is very helpful.
So when it flashes the 24 code then I need to address only the 24-1 on the sheet you sent? When I checked connections there was water in some of the connections close to the PCM but not in the PCM connectors. No water in the shift motor connectors.
Reactions: Lady01
