P1000 Gear Shift Problem with Codes
Travis R
Travis R
154
485
Southeast Louisiana
Good morning from Southeast Louisiana! I got a quick question.
Should I buy an aftermarket shift motor or Honda the OEM?
My cousin has a new aftermarket shift motor for his 2013 Honda Rancher 420 that’s never been used and I thought about buying it from him.
What do y’all recommend?
Thank you and have a blessed day!
DRZRon1
DRZRon1
1,442
4,398
PA
You can try by cleaning it first.Then Honda shift motor imo.
agree - still at step 1, inspect, clean, etc. - it could be a bad connector \wire for all we know
honestly I have bought both - the non-ronda for a P500 and a Honda OEM for a P1000 - they both looked the same and both worked so who knows
Try it if he’s not planning to take it back.
But I think good chance that’s your problem. A friend of mine had same symptoms so we tore into it and just cleaned it, problem was solved.
DRZRon1
DRZRon1
1,442
4,398
PA
its basically a mini DC motor similar to a car starter, no bend-ix, direct drive - flop polarity to drive it forward\reverse to switch gears, so it has brushes inside for the commutator - it could just be glazed over and dirty - who knows unless you look - I fixed my buddies P500, the shift motor the magnets cracked inside and came loose and would lock up the rotor, bought the non honda shift motor and put in and al was fine - we did go after connections, wiring first then were just looking to clean it
Reactions: Travis R
116,574
It was for his 2013 Rancher 420 lol
glad u got it fixed. now get that thing snorkled before u have serious problems. again u do have a 16'.
also work on getting a dual battery set up and put the radio, light bar and winch on it. These rigs like pure voltage from the main battery to shift correctly
Reactions: Travis R
john790
399
1,154
Clinton ohio 44216
I have to give this the WOW factor for the fact the shift motor is so standard for different models.Same wiring ????
Reactions: RacinJasonWV
DRZRon1
DRZRon1
1,442
4,398
PA
it’s like wheel brake cylinders on a Chevy - same cylinder used from the 50’s and up - if it ain’t broke - don’t fix it
Reactions: Travis R
Travis R
Travis R
154
485
Southeast Louisiana
Anybody know if it’s possible to have my original shift motor rebuilt for a spare? There’s a local alternator/starter electrical repair shop close to my location.
I got the old motor apart and everything has black dust inside but the magnets are not broke. Thanks
DRZRon1
DRZRon1
1,442
4,398
PA
anything is possible - but really - its like a $50 part
if the rotor is bad nobody is gonna rebuild a rotor and charge you less than $50 - here is my opinion
-if the brushes don't look worn down and are under tension, clean it, lightly sand the commutator with scotch brite and try it on your machine.
if its junk and you want a spare - just order a new one
good luck - glad your machine is back up
